I’m trying to add my Hue Hub to Hubitat but it’s not self discovering. Other Hue compatible apps can find it without an issue.
Is there any way to point Hubitat to the IP of the Hue Hub to skip the set discovery step?
Are you using the Hue Bridge Integration App?
Yep, that’s correct
It's been a couple of years since I connected mine using that app and if I remember correctly it found it OK with no issues.
I don't know of any way to 'point' it to the Hue Bridge.
Not sure what to suggest I'm afraid.
Maybe a reboot of both hubs may kick it into life. Not sure. Sorry.
Also, if you're trying to add a second Hue bridge, make sure you install a second copy of the Hue Bridge Integration App.
A minor addition to what @bobbles and @ogiewon have said. The Hubitat hub and Hue bridge have to be in the same subnet/VLAN.
