I have 6 devices stranded on Smartthings because I could never get them to integrate with Hubitat. Four Bali blinds and two Schlage Locks. I have been using Hubithings to control them. After upgrading to C8, these devices no longer update their status. I can still control them, just no correct status. Poking around in the Hubithings app I wound up at a pull down menu to select a location. My new C8 hub is not listed, just the old C7. This may or may not age my issue. Any suggestions?
Go into the OAuth UI and hit ‘Delete API’ and then rebuild the connection. Your devices will be saved and reauthorized.
The new hub has a different HTTPS webhook.
Thanks for the tip. Working correctly now.
