Hi - I'm been using and loving HubitatAlarm for over a year now. With the latest Hubitat version (2.4.3.137) it seems to have broken my motion sensors. The contact sensors and general alarm control are still working fine.
My previous version was 2.4.3.133, this was the last FW that worked.
Did anything change in 2.4.3.137 that would affect a "Generic Component Motion Sensor" type?
Do you see any errors in Logs? There were minor changes to some generic component drivers recently to accommodate battery reporting, but it shouldn't affect well written parent apps/devices.
@bertabcd1234 - thanks for the response.
I looked at the logs, and do not see any errors.
I was going to put some additional log messages in the driver to see if I can see what changed between the good and bad case.
But after downgrading to the older Hubitat FW, the motion sensor works.
I've put some debug messages in the driver and found something strange...
I've put a snip of the driver below where I've added 2 debug messages, If I use the first one, it works, but if I comment out the 1st one and uncomment the 2nd one, it does not work.
It seems that by just reading this value ( zoneChildDevice.supportedAttributes[0].toString() == "motion") in the log message causes it to work. May there is a race condition?
Any ideas why this would start happening on the latest FW?
log.debug("Hubitat Alarm Panel - alarmZoneparse Processing command: $evt")
def zoneChildDevice = getChildDevice("${evt.type}-${evt.zone}")
// working debug
log.debug("!!!!!! DEBUG - ${evt.type}-${evt.zone} ${evt.state} ${zoneChildDevice.supportedAttributes[0].toString()}!!!!!!")
// not working debug
// log.debug("!!!!!! DEBUG - ${evt.type}-${evt.zone} ${evt.state} !!!!!!")
if(evt.state == "open"){
log.warn("Zone child device evt.state ${evt.state}")
if(zoneChildDevice.supportedAttributes[0].toString() == "contact"){
zoneChildDevice.sendEvent(name: "contact", value: "open")
if(zoneChildDevice.supportedAttributes[0].toString() == "motion"){
log.error "!!!! Motion Active !!!!"
zoneChildDevice.sendEvent(name: "motion", value: "active")
if(zoneChildDevice.supportedAttributes[0].toString() == "smoke"){
zoneChildDevice.sendEvent(name: "smoke", value: "detected")
else if(evt.state == "closed"){
zoneChildDevice.sendEvent(name: "contact", value: "closed")
log.error "!!!! Motion Inactive !!!!"
zoneChildDevice.sendEvent(name: "motion", value: "inactive")
zoneChildDevice.sendEvent(name: "smoke", value: "clear")
I saw this in another driver recently and am not sure why any author would have made that choice (the order of attributes is entirely arbitrary, but if you only have one, I suppose the "first" would happen to always work...). But it looks like the same cause here.
As a quick fix, something like zoneChildDevice.supportedAttributes.find { it.toString() == "contact" } would be the most similar, though I don't really see why getting the entire object is necessary at all, and I wouldn't have made the choice to depend on the provided string converter when the object has a name property. I'd probably do something like:
zoneChildDevice.supportedAttributes.any { it.name == "contact" }
...and similar for the other attributes.
@bertabcd1234 - I think that did it!
I added some additional debug code:
zoneChildDevice.supportedAttributes.each { attr ->
log.debug "!!! Attribute name: ${attr.name}"
And it prints:
dev:37922025-10-21 08:35:57.549 PMdebug!!! Attribute name: motion
dev:37922025-10-21 08:35:57.548 PMdebug!!! Attribute name: battery
So I'm guessing on older FW, "motion" was first, and on new FW "battery" is first, causing it to miss the IF condition. This is no longer an issue when using your suggestion.
Thank you for your help, I'm back up and running!
Victor
October 22, 2025, 2:54pm
7
I'm the author of this App. I didn't realize it stopped working with the recent update either. I'll test the suggested change today and update it in the Hubitat Package manager as well.
Hi Victor. Please post back when there is an update. I have motion, contact, and smoke detectors, and it is not working.
HPM says I have versions:
Hubitat Alarm v1.0.1 (app)
Hubitat Alarm Panel v1.0.1 (driver)
If you wish any tests or such please let me know.
Thank you.
@abordercollie - if you want a temporary work around, you can try this modified version of the "Hubitat Alarm Panel" driver:
metadata {
definition (name: "Hubitat Alarm Panel", namespace: "hubitatalarm", author: "victor@hepoca.com") {
capability "Initialize"
capability "Alarm"
capability "Switch"
capability "Refresh"
attribute "alarmStatus", "string"
attribute "systemStatus", "string"
attribute "chime", "string"
command "armAway"
command "armHome"
command "armNight"
command "disarm"
command "chimeToggle"
command "alarmSetDate"
def installed(){
addChildDevices()
webSocketConnect()
def updated(){
addChildDevices()
webSocketConnect()
def initialize() {
webSocketConnect()
def uninstalled(){
removeChildDevices()
private addChildDevices() {
def zoneSettings = parent.getZonesSettingsChild()
zoneSettings.each {
def deviceId = it.networkId
def deviceType = it.type == "contact" ? "Generic Component Contact Sensor" : it.type == "motion" ? "Generic Component Motion Sensor" : "Generic Component Smoke Detector"
if (!getChildDevice(deviceId)) {
def d = addChildDevice("hubitat", deviceType, deviceId, ["name": it.name, label: it.name, isComponent: true])
log.info("Hubitat Alarm - Added zone device: DisplayName: ${d.displayName} - deviceId: ${deviceId}")
getChildDevices().each{
def findalldev = !zoneSettings.findAll{z -> z.networkId == it.deviceNetworkId}
if(findalldev){
log.info("Hubitat Alarm - Orphan Child Device detected. Deleting DisplayName: ${it.displayName} - deviceId: ${it.deviceNetworkId}")
deleteChildDevice(it.deviceNetworkId)
private removeChildDevices() {
getChildDevices().each { deleteChildDevice(it.deviceNetworkId) }
log.info("Hubitat Alarm Panel - Removing all Zones child devices")
def alarmPanelparse(evt) {
log.debug("Hubitat Alarm Panel - alarmPanelparse Processing command: $evt")
sendEvent(name: "systemStatus", value: evt.description)
if(location.hsmStatus == "armedAway" || location.hsmStatus == "armedHome" || location.hsmStatus == "armedNight"){
sendEvent(name: "switch", value: "on")
else{
sendEvent(name: "switch", value: "off")
// handle DSC Arm/Disarm modes
if(evt.hsmstate){
log.info("Hubitat Alarm Panel - alarmPanelparse Checking if event is 652 evt.code: ${evt.code}")
if(evt.code == "652"){
log.info("Hubitat Alarm Panel - alarmPanelparse Checking location.hsmStatus: ${location.hsmStatus}")
log.info("Hubitat Alarm Panel - alarmPanelparse Alarm already armed. returning.")
return
parent.updateAlarmHSM(evt.hsmstate)
sendEvent(name: "alarmStatus", value: evt.hsmstate)
if(evt.code == "901"){
sendEvent(name: "chime", value: evt.state)
log.warn("evt.description ${evt.description}")
def alarmZoneparse(evt) {
log.debug("!!!!!! DEBUG - ${evt.type}-${evt.zone} ${evt.state}!!!!!!")
if(zoneChildDevice.supportedAttributes.any { it.name == "contact" }){
if(zoneChildDevice.supportedAttributes.any { it.name == "motion" }){
if(zoneChildDevice.supportedAttributes.any { it.name == "smoke" }){
def off() {
log.info("Hubitat Alarm Panel - issued command: Off")
sendAlarmCommand("alarmDisarm")
def on() {
log.info("Hubitat Alarm Panel - issued command: On")
sendAlarmCommand("alarmArmAway")
def armAway() {
log.info("Hubitat Alarm Panel - Sending armAway")
def armNight() {
log.info("Hubitat Alarm Panel - Sending armNight")
sendAlarmCommand("alarmArmNight")
def armHome() {
log.info("Hubitat Alarm Panel - Sending armHome")
sendAlarmCommand("alarmArmStay")
def disarm() {
log.info("Hubitat Alarm Panel - Sending disarm")
def chimeToggle() {
log.info("Hubitat Alarm Panel - Sending Toggling chime")
sendAlarmCommand("alarmChimeToggle")
def siren() {
log.info("Hubitat Alarm Panel - Sending alarmPanic")
sendAlarmCommand("alarmPanic")
def strobe() {
log.info("Hubitat Alarm Panel - Sending alarmFire")
sendAlarmCommand("alarmFire")
def alarmSetDate() {
log.info("Hubitat Alarm Panel - Sending alarmSetDate")
sendAlarmCommand("alarmSetDate")
def refresh() {
log.info("Hubitat Alarm Panel - Sending alarmUpdate")
sendAlarmCommand("alarmUpdate")
def sendAlarmCommand(command) {
if(parent.getSettings().communicationType == "API"){
def path = "/api/$command"
sendAsynchttpGet(path,'sendAlarmCommandcallback')
else if(parent.getSettings().communicationType == "WSS"){
interfaces.webSocket.sendMessage('{"command":"' + command + '"}')
def sendAlarmCommandcallback(response, data){
try{
log.info("Hubitat Alarm Panel - sendAlarmCommandcallback http response code: ${response.status} http response data ${response.errorData}")
catch(e){
log.info("Hubitat Alarm Panel - sendAlarmCommandcallback http response code: ${response.status}")
def sendAsynchttpGet(path,callback) {
def parentSettings = parent.getSettings()
def getParams = [
uri: "http://$parentSettings.proxyAddress:$parentSettings.proxyPort/$path"
asynchttpGet(callback, getParams)
def webSocketConnect(){
try {
interfaces.webSocket.connect("ws://$parentSettings.proxyAddress:$parentSettings.proxyPort/wss", pingInterval: 60)
catch(e) {
log.error "Hubitat Alarm Panel - WebSocket connect failed error: ${e.message}"
else if(parent.getSettings().communicationType == "API"){
interfaces.webSocket.close()
def webSocketStatus(String status){
log.debug "Hubitat Alarm Panel - WebSocket webSocketStatus ${status}"
if(status.contains("failure:")) {
log.warn("Hubitat Alarm Panel - WebSocket failure message from web socket ${status}")
reconnectWebSocket()
else if(status == 'status: open') {
log.info "Hubitat Alarm Panel - WebSocket is open"
else if (status == "status: closing"){
log.warn "Hubitat Alarm Panel - WebSocket connection closing."
else {
log.warn "Hubitat Alarm Panel - WebSocket error, reconnecting."
def reconnectWebSocket() {
log.info("Hubitat Alarm Panel - WebSocket reconnecting in 10 seconds")
runIn(10, webSocketConnect)
// This method must exist
// it's used by hubitat to process the device message
def parse(evt) {
try{
def map = parseLanMessage(evt)
def headers = map.headers;
def body = map.data;
if (headers.'device' != 'alarm') {
log.debug("Hubitat Alarm - Received event ${evt} but it didn't came from Alarm")
return
log.debug("Hubitat Alarm Panel: Received Command ${body}")
if(body.type == "partition"){
// process Alarm panel partition event
alarmPanelparse(body)
else if(body.type == "zone"){
// process Alarm zone event
alarmZoneparse(body)
catch(MissingMethodException){
// these are events with description: null and data: null, so we'll just pass.
pass
// process WSS message
try{
def wssevt = new groovy.json.JsonSlurper().parseText(evt)
log.warn("Hubitat Alarm Panel - WSS received command ${wssevt}")
if(wssevt.type == "partition"){
alarmPanelparse(wssevt)
else if(wssevt.type == "zone"){
alarmZoneparse(wssevt)
catch(e){
log.debug("Hubitat Alarm Failed to parse json wssevt = ${e}")
return
Thank you... that did it I can confirm all is working again.
Victor
October 23, 2025, 4:45pm
11
All done.
Just added the suggested change and updated the Hubitat Package manager.
Fixed on 1.0.2
