I am trying to trigger an event from a timer. In this case disarm the HSM at a certain time. But when the time is reached nothing happens.
I tried changing it to turn a light on to see if it was a problem with the HSM, but still nothing.
If I run actions then the light switches on okay.
I’ve also checked that the time zone is correct, which it is.
Sorry just going to start with the most basic - did you remember to click "Done" after creating or editing the rule? Also it probably wouldn't hurt to click "Update Rule" before "Done". I can't actually see anything wrong with your simple rule!
But do you have the latest hub update? Just in case you have a build that had a bug in rules.
Thanks for that. That indirectly solved the problem.
I did the update rule and done as you suggested and it didn’t make any difference.
So next I went off to find the hub version and noticed on the hub details page that the time was an hour out. I assume it doesn’t take account of BST. Updated the time from the browser, tried again and it then worked.
I had a feeling it was going to be something daft.
Thanks for replying and setting me on the right track.
And thanks for coming back to let us know what the real problem was - that will be another basic question I can ask someone with a time-trigger problem
