Hubitat virtual button change state/color when pushed?
I made a v-button to turn off all lights. ( its just fine )
But unlike the "regular" buttons when you click it it stays gray.
I would like it turn color when pressed so you know / see it being pushed.
Anyway to make this happen ?
When you say a regular button, what exactly do you mean? Are you referring to the way a switch turns a certain color?
Also, how do you want it to behave? Do you want the tile to temporarily change color to signify the press, then return to the normal tile color? Or something else?
Depending on what you want to achieve you may be able to use a virtual switch with an automatic off option enabled. May not suit all circumstances, particularly multi-button devices, plus you lose the button controller option, but it may suit some simpler scenarios.
< Yes this would be great :slight_smile:
Then I expect the virtual switch may be worth a look, however you will need to change the way you trigger the lights to turn off, to use the switch turning on rather than the button press. Plus, in the dashboard you will need to use the switch rule template instead of a button.
