Good day everyone,
I couldn't find a better place for asking a question that relates to Hubitat Simple Lighting.
I have the rule below that turns on a Kitchen Accent Light when it detects motion using my Great Room Motion Sensor.
It works fine when you go in the kitchen to grab a drink or something else and then leave and the lights turn off automatically.
However if you go to the Kitchen to make dinner where the motion sensor might not pick motion for about 5 minute, for example when preparing a salad, the lights will turn off after 5 minutes even when you have turned off the lights manually and turned them back on manually again in an attempt to override them auto turn off feature of the Simple Lighting rule that has already ran ("Turn off when motion stops" toggle feature).
Is there a way to cancel the turn off part of the already executed Simple Lighting rule when the light is turned on manually? Should I just create a separate rule to turn off the light automatically instead of using the "Turn off when motion stops" toggle feature?
Please advise
