My HSM config screens don't look like the documentation. No noncustom configuration screens . What have I done wrong
Some screenshots would be useful here ....
...and do you have sensors that HSM can monitor?
Door lock and thermostat
Believe itโs looking for devices that have capability sensor (contact and motion specifically) which lock and thermostat generally donโt support.
Such as door or window closed switch ?
A door or window contact switch should be found if included. Could add a virtual to test the theory if you like.
I will give it a try. Thanks
Adding a virtual switch seems to enable non custom HSM. Thanks again
