I think it's implemented. It would be location.hsmStatus
. I believe it was in the most recent release.
That worked. Thanks!
@bravenel
I added this command to a method but when trying to save changes I get the following:
Invalid variable name. Must start with a letter but was: “hsmSetArm” . At [579:29] @ line 579, column 29.
Please advise.
When trying to save the app?
Yup
If you copied/pasted there's something weird going on with the quotes. Try replacing manually.
This works just fine, and the comment about quotes is no doubt your problem.
definition(
namespace: "hubitat",
author: "Bruce Ravenel",
description: "test app",
category: "Convenience",
iconUrl: "",
iconX2Url: ""
preferences {
section {
def installed() {
initialize()
def updated() {
initialize()
def initialize() {
sendLocationEvent(name: "hsmSetArm", value: "blahblah")
Indeed it was the problem. This is the 3rd time these quotations have got me. You'd think I would have learned by now. Thank you sir.
Yes, something detestable about Discourse, for sure!
So it saved fine but does not appear to be changing the HSM armed state.
Strike that @bravenel
It appears that you cannot switch between armAway and armHome. If I disarm first and then set to one of the armed modes it works. Wasn't aware that there were limits on what mode could switch to another.
Ah, that's a bug. Just tried, and got unexpected response.
The bug is trivial to fix. But it won't be in the release coming out today. Next one after that.
When I subscribe:
subscribe(location, “hsmStatus”, statusHandler)
I'm getting:
Invalid variable name. Must start with a letter but was: “hsmStatus” . At [219:25] @ line 219, column 25.
Check your double quotes (as mentioned for the exact same error a few posts above )
should be
subscribe(location, "hsmStatus", statusHandler)
Oh, thanks. Man I gotta keep an eye on that. Copy and paste from this form always results in that.
Please note a correction to the API shown above. There are two separate intrusion alert values for hsmAlert. "intrusion" means an intrusion alert when armed-away, and "intrusion-home" means an intrusion when armed-home.
@bravenel it would be very nice to have an "armed night" mode, which is commonly available in other security systems
HSM has “Armed-Home”, is that what you are referring to? That is what I use for night time.
home and night would be two different modes, with more sensors active and night but still less than away
