Hubitat™ Safety Monitor and Rule Machine bug?
noticed in
Hubitat™ Safety Monitor - water
both options
"Include alerting device name?"
and
"Use every water sensor"
refuse to turn on
just means I have to create an alert for each water sensor if I want to have it identified in a text alert.
I also noticed "Include device name?" refuses to turn on in Rule Machine as well.
I tired removing and reinstalling them but the same results.
Will investigate…
What os, browser and hub firmware are you using? I tried windows 10 chrome and android chrome with latested 701 with no issue.
Fresh install on fresh hub. Don't even have any water sensors (it doesn't know that). What browser?
running Windows 10 pro 64 bit and Google Chrome Version 64.0.3282.18
disabled ABP extension and AVG antivirus but still the same issue
Confirmed the above, I’m able to set the “use every water sensor” setting above, and I don’t have any sensors either.
You didn’t confirm the hub firmware. Are you on the latest .701?
I found the problem it was a Chrome extension for video streaming causing a conflict for some reason (tested turning the extension on and off) disabled it and Hubitat is working fine now.
But good to know conflicting Chrome extension may cause other issues
thanks
I have chrome, firefox and edge on my w10 machine just for this reason. If I get a weird glitch I try another browser.
