Hubitat Refused to Connect on Registration
Hello Support,
I have a brand new device.
The device is connected directly to an Amplifi router.
I am on a computer that is on the same network as the Hubitat
When I log into portal.hubitat.com the device shows up with the green button "Registered Hub"
When I click the registered hub I get:
This site canโ€™t be reached
192.168.176.119 refused to connect.
ERR_CONNECTION_REFUSED
I've unplugged the device several times and each time I get the same response. Please help. I'm located in Washington (PST)
Thanks for reporting. A fix is in the works, should be up shortly.
You may need to refresh your browser or clear your cache for portal.hubitat.com but the fix has been deployed and should be available now.
Thank you Patrick.
Everything is working now!
I am having the same issue. I have tried clearing cache and refreshing. tried from multiple browsers, restarted hubitat etc.... Any suggestions?
