Hubitat Package Manager - Hubigraph Install error
Hi
When installing Hubigraphs I get the following error
Error Occurred During Installation
An error occurred while installing the package: Failed to install file https://raw.githubusercontent.com/tchoward/Hubitat/master/HubiGraph.js. Please notify the package developer..
The logs show:-
2021-01-08 12:12:29.926 infoFatal error occurred, rolling back
app:3222021-01-08 12:12:29.920 errorError installing file: groovyx.net.http.HttpResponseException: Server Error
app:3222021-01-08 12:12:29.703 infoInstalling https://raw.githubusercontent.com/tchoward/Hubitat/master/HubiGraph.js
Not sure who I am supposed to inform?
Is there a manual way to install this?
Mike
Hey all, I got the same error.
I have tried multiple times and get the same error.
I have rebooted HE
I have powered off - waited 10 seconds - powered HE back up
Same error :frowning:
You should post this in the original thread to ensure the author sees it.
@CAZ thanks I have just wasn't sure if it was a HPM or HG issue - posted in both :slight_smile:
No worries. Have you tried to install it manually? If that doesn't work either it's HG.
I found instructions for a manual install - that got basic line graphs working trying to find instructions to get everything else working
Found a whole pile of HG apps - trying those
In HPM can you see if HG is installed?
If not try doing a Match Up in HPM.
If it does show maybe try a repair. This should download all the files.
It's been awhile since I installed HG and don't think I had any issues but doing the above might be worth trying.
@bobbles GOOD CALL - trying now
Darn it soooooo close ....
Tried a HPM Repair :frowning:
« App List
settings
help
Repairing Package
Your changes are currently in progress... Please wait...
Downloading https://raw.githubusercontent.com/tchoward/Hubitat/master/HubiGraph.js
Downloading https://raw.githubusercontent.com/tchoward/Hubitat/master/WeatherTile.js
Downloading https://raw.githubusercontent.com/tchoward/Hubitat/master/WeatherTile2.js
Downloading https://raw.githubusercontent.com/tchoward/Hubitat/master/WeatherTile2.css
Downloading Hubigraphs
Downloading Hubigraph Line Graph
Downloading Hubigraph Gauge
Downloading Hubigraph Time Line
Downloading Hubigraph Range Bar
Downloading Hubigraph Bar Graph
Downloading Hubigraph Time Graph because it is required and not installed
Downloading Hubigraph Heat Map
Downloading Hubigraph Weather Tile because it is required and not installed
Downloading Hubigraph Forecast Tile because it is required and not installed
Downloading Hubigraph Radar Tile because it is required and not installed
Downloading Hubigraph Weather Tile 2 because it is required and not installed
Downloading Hubigraph Tile Device
Downloading Hubigraph OpenWeather Device because it is required and not installed
Reinstalling Hubigraphs
Reinstalling Hubigraph Line Graph
Reinstalling Hubigraph Gauge
Reinstalling Hubigraph Time Line
Reinstalling Hubigraph Range Bar
Reinstalling Hubigraph Bar Graph
Installing Hubigraph Time Graph
Reinstalling Hubigraph Heat Map
Installing Hubigraph Weather Tile
Installing Hubigraph Forecast Tile
Installing Hubigraph Radar Tile
Installing Hubigraph Weather Tile 2
Reinstalling Hubigraph Tile Device
Installing Hubigraph OpenWeather Device
Seems like it is to do with the hubigraph.js file.
How about trying a manual install of just that file and see what happens. Might be worth a try.
I am up for that, I have installed Apps and Drivers,
Do I install as an App?
I have put up manual install instructions for those interested at HubiGraph Manual Install
I'm pretty new here too. More familiar with Vera and learning and liking Hubitat thanks to you with this Hubigraph stuff. I get to JAVA and the instructions trail off for me too. How does one download a .js file? It seems simple...click on link and opt to download but mine comes up in Browser full text and no option to download.
