Hubitat is non operational, worked fine for a little over one year... then had a few errors and slowly stopped operating devices. I removed the non operating devices. at this point out of about 50 devices only a few will work sporadically. IThe last month has been a disaster, it controls too much at our home to give it up at this point and now we are going out of town and I am heading to buy timers for aquarium lighting. It's needing restarted to give one signal then the next morning again needs restarted.
I need help and I have no idea where to start on thing.
thanks,
Ernie
there are hundreds of lines of this in the log:
dev:2892019-12-24 01:10:12.801 pm error Connections could not be acquired from the underlying database!
dev:2892019-12-24 01:10:09.097 pm error Connections could not be acquired from the underlying database!
dev:2892019-12-24 01:08:12.137 pm error Connections could not be acquired from the underlying database!
dev:2892019-12-24 01:08:12.128 pm error Connections could not be acquired from the underlying database!
dev:2942019-12-24 01:08:08.522 pm error java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:2892019-12-24 01:08:08.484 pm error java.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:2892019-12-24 01:08:08.434 pm error Connections could not be acquired from the underlying database!
dev:2312019-12-24 01:07:27.880 pm debug Executing 'refresh'
dev:2892019-12-24 01:05:56.756 pm error java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:2892019-12-24 01:05:56.660 pm error Connections could not be acquired from the underlying database!
dev:2892019-12-24 01:05:52.940 pm error java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:2892019-12-24 01:05:52.880 pm error java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:2592019-12-24 01:02:58.108 pm error java.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:2572019-12-24 12:58:36.896 pm error java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:2572019-12-24 12:58:36.837 pm error An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down.
dev:2312019-12-24 12:58:36.851 pm error java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (refresh)
