Hi β have been working on getting my konnected / Hubitat Elevation Hub system up and running. Previously (several months ago) wired in the konnected boards and then installed the hub, added the konnected apps and drivers, and everything looked pretty good. Could see on a device page the change of opening and closing a door. Got busy and left it alone for a few months until now. Came back to the system and was also armed with a phone that could run the Hubitat app a few days ago. Had initial issue finding the hub β had remove and replace its power to get it to show on the router. Once I was in, I updated the hub software, but then found all the βdevicesβ were static β none were updating. I could open doors but the device page and dashboard showed continuously closed (unchanged). Looked at the logs and device events and found that nothing had changed status since May (now the end of July).
I looked for answers/fixes and stumbled upon this page - Konnected alarm boards not seen once added
It looked similar to my issue and pointed to a range extender on the wifi as a causal factor (MAC spoofing of the konnected cards). Since I have a range extender I did as discussed on the page and re-installed everything with the range extender powered off. Did a soft reset of the Hubitat hub, flashed all four of my konnected modules, reinstalled everything (apps & drivers). I could not get the Hubitat Hub to discover any of my konnected boards. I looked at my router and the boards were there with their proper MAC addresses β but the Hub simply would not discover themβ¦.. I found that if I restored the Hub to an earlier software version, the discovery and zone definatization process worked as advertised (and as it had done months ago initially). I had two old configuration choices and I chose β2.0.9.133β as it was the earliest of the choices displayed β was probably what the hub was shipped with.
So with all re-installed and the range extender still off, I re-created a dashboard and tested many of the sensors throughout the house and found them to be working β went to bed feeling pretty good
I took a look at my dashboard around noon the next day (wifi range extender still off) and found it again was frozen (shut doors would show shut with door open). Went to the computer to pull up the hub portal and could not find the Hubitat Hub. Checked the router page and it showed the konnected boards but not the Hubitat Hub MAC. I cycled power to the Hub and it appeared on the router page at a different IP address from before (as expected) but I was able to get into the portal at this point. Found myself back where I was at the beginning. The Hub appeared to stop updating status of the zones between 0845 and 0920 this morning and I cannot get it work.
Looking for help as I am out of things to try and have poured over the existing posts to avoid posting my ineptness. I have attached the Hubitat portal log and a screenshot of a device (door sensor β door was open when screen shot was taken).
Really it comes down to a few questions:
- Why would I need to go to an old Hubitat software load to enable discovery of konnected devices?
- Why does my Hub disappear from the router after 9 or 10 hours? And require a power cycle to come back online?
- Why does the Hubitat hub stop updating status changes of the konnected devices?
- What do I need to do to make the system work as advertised? Do I need a new Hub? Is there bad code somewhere? Am I just doing something wrong?
- Why does it appear to be working fine for a few hours and then stop working all together?
Thx v/r Wood
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 10:00:02.443 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 10:00:02.059 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:55:02.530 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:55:02.495 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:55:02.482 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:55:02.460 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:55:02.106 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:50:02.513 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:50:02.489 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:50:02.482 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:50:02.461 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:50:02.063 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:45:02.460 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:45:02.456 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:45:02.411 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:45:02.382 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:45:02.086 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:40:02.711 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:40:02.688 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:40:02.635 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:40:02.589 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:40:02.107 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:35:02.567 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:35:02.507 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:35:02.517 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:35:02.068 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[dev:18](http://192.168.1.18/logs/past#dev18)2019-07-25 09:30:04.430 am [debug](http://192.168.1.18/device/edit/18)Mike's Garage to House Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:30:04.418 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|5 = 0
[dev:17](http://192.168.1.18/logs/past#dev17)2019-07-25 09:30:04.057 am [debug](http://192.168.1.18/device/edit/17)Family Room Motion Detector is inactive
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:30:04.037 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|6 = 0
[dev:16](http://192.168.1.18/logs/past#dev16)2019-07-25 09:30:03.656 am [debug](http://192.168.1.18/device/edit/16)Front Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:30:03.645 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|1 = 0
[dev:15](http://192.168.1.18/logs/past#dev15)2019-07-25 09:30:03.250 am [debug](http://192.168.1.18/device/edit/15)Ambia's Garage to House Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:30:03.239 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|2 = 0
[dev:14](http://192.168.1.18/logs/past#dev14)2019-07-25 09:30:02.920 am [debug](http://192.168.1.18/device/edit/14)Master Bedroom to Lanai Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:30:02.908 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|9 = 0
[dev:13](http://192.168.1.18/logs/past#dev13)2019-07-25 09:30:02.569 am [debug](http://192.168.1.18/device/edit/13)CO detector by Nook is clear
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:30:02.556 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:30:02.547 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|7 = 0
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:30:02.512 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:30:02.485 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:30:02.503 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:30:02.104 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:25:02.500 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:25:02.490 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:25:02.478 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:25:02.397 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:25:02.092 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[dev:6](http://192.168.1.18/logs/past#dev6)2019-07-25 09:23:15.495 am [debug](http://192.168.1.18/device/edit/6)Family Room to Lanai Door is closed
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:23:15.484 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|5 = 0
[dev:5](http://192.168.1.18/logs/past#dev5)2019-07-25 09:23:15.125 am [debug](http://192.168.1.18/device/edit/5)Dining Nook to Lanai Door is closed
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:23:15.103 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|6 = 0
[dev:4](http://192.168.1.18/logs/past#dev4)2019-07-25 09:23:14.693 am [debug](http://192.168.1.18/device/edit/4)Master Bedroom Windows (5) is closed
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:23:14.681 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|1 = 0
[dev:3](http://192.168.1.18/logs/past#dev3)2019-07-25 09:23:14.339 am [debug](http://192.168.1.18/device/edit/3)Master Bath Windows (2) is closed
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:23:14.328 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|2 = 0
[dev:2](http://192.168.1.18/logs/past#dev2)2019-07-25 09:23:13.941 am [debug](http://192.168.1.18/device/edit/2)Cabana Bath to Lanai Door is closed
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:23:13.931 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|9 = 0
[dev:1](http://192.168.1.18/logs/past#dev1)2019-07-25 09:23:13.561 am [debug](http://192.168.1.18/device/edit/1)Triple Slider to Lanai Door is closed
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:23:13.543 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|7 = 0
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:20:02.464 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:20:02.456 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:20:02.399 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:20:02.327 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:20:02.059 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:15:02.070 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:10:02.085 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:05:02.571 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:05:02.555 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:05:02.554 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:05:02.408 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:05:02.093 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[dev:6](http://192.168.1.18/logs/past#dev6)2019-07-25 09:00:25.418 am [debug](http://192.168.1.18/device/edit/6)Family Room to Lanai Door is closed
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:00:25.406 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|5 = 0
[dev:6](http://192.168.1.18/logs/past#dev6)2019-07-25 09:00:22.090 am [debug](http://192.168.1.18/device/edit/6)Family Room to Lanai Door is open
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:00:22.078 am [debug](http://192.168.1.18/installedapp/configure/41)Received sensor update from Konnected device: BCDDC29DEF3F|5 = 1
[dev:17](http://192.168.1.18/logs/past#dev17)2019-07-25 09:00:15.258 am [debug](http://192.168.1.18/device/edit/17)Family Room Motion Detector is inactive
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:00:15.238 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|6 = 0
[dev:17](http://192.168.1.18/logs/past#dev17)2019-07-25 09:00:14.431 am [debug](http://192.168.1.18/device/edit/17)Family Room Motion Detector is active
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:00:14.408 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|6 = 1
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 09:00:02.480 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 09:00:02.479 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 09:00:02.494 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 09:00:02.466 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 09:00:02.088 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[dev:18](http://192.168.1.18/logs/past#dev18)2019-07-25 08:55:04.364 am [debug](http://192.168.1.18/device/edit/18)Mike's Garage to House Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:55:04.352 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|5 = 0
[dev:17](http://192.168.1.18/logs/past#dev17)2019-07-25 08:55:03.982 am [debug](http://192.168.1.18/device/edit/17)Family Room Motion Detector is inactive
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:55:03.970 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|6 = 0
[dev:16](http://192.168.1.18/logs/past#dev16)2019-07-25 08:55:03.645 am [debug](http://192.168.1.18/device/edit/16)Front Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:55:03.634 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|1 = 0
[dev:15](http://192.168.1.18/logs/past#dev15)2019-07-25 08:55:03.262 am [debug](http://192.168.1.18/device/edit/15)Ambia's Garage to House Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:55:03.251 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|2 = 0
[dev:14](http://192.168.1.18/logs/past#dev14)2019-07-25 08:55:02.903 am [debug](http://192.168.1.18/device/edit/14)Master Bedroom to Lanai Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:55:02.883 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|9 = 0
[dev:13](http://192.168.1.18/logs/past#dev13)2019-07-25 08:55:02.541 am [debug](http://192.168.1.18/device/edit/13)CO detector by Nook is clear
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:55:02.521 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|7 = 0
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:55:02.477 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 08:55:02.459 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 08:55:02.439 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 08:55:02.437 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 08:55:02.111 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:50:02.679 am [debug](http://192.168.1.18/installedapp/configure/43)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189df136::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80108, mac:BCDDC29DF136, ssdpNTS:null]
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 08:50:02.662 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
[app:42](http://192.168.1.18/logs/past#app42)2019-07-25 08:50:02.632 am [debug](http://192.168.1.18/installedapp/configure/42)Refreshed attributes of device [deviceAddress:47ad, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189dea7a::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80103, mac:BCDDC29DEA7A, ssdpNTS:null]
[app:41](http://192.168.1.18/logs/past#app41)2019-07-25 08:50:02.560 am [debug](http://192.168.1.18/installedapp/configure/41)Refreshed attributes of device [deviceAddress:47ae, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259189def3f::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80113, mac:BCDDC29DEF3F, ssdpNTS:null]
[app:1](http://192.168.1.18/logs/past#app1)2019-07-25 08:50:02.096 am [debug](http://192.168.1.18/installedapp/configure/1)Discovering Konnected devices on the network via SSDP
[dev:18](http://192.168.1.18/logs/past#dev18)2019-07-25 08:45:34.561 am [debug](http://192.168.1.18/device/edit/18)Mike's Garage to House Door is closed
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:45:34.542 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|5 = 0
[dev:18](http://192.168.1.18/logs/past#dev18)2019-07-25 08:45:32.024 am [debug](http://192.168.1.18/device/edit/18)Mike's Garage to House Door is open
[app:43](http://192.168.1.18/logs/past#app43)2019-07-25 08:45:32.001 am [debug](http://192.168.1.18/installedapp/configure/43)Received sensor update from Konnected device: BCDDC29DF136|5 = 1
[app:44](http://192.168.1.18/logs/past#app44)2019-07-25 08:45:02.650 am [debug](http://192.168.1.18/installedapp/configure/44)Refreshed attributes of device [deviceAddress:2b88, ssdpTerm:urn:schemas-konnected-io:device:Security:1, serialNumber:, hub:1, name:, verified:true, ssdpPath:/Device.xml, model:Konnected, ssdpUSN:uuid:8f655392-a778-4fee-97b9-48259182ffa46::urn:schemas-konnected-io:device:Security:1, networkAddress:C0A80105, mac:ECFABC2FFA46, ssdpNTS:null]
