Hi All, can someone help me, find the reason why my hub keeps crashing, I contacted Hubitat customer services and they think its an installed Driver or App, here installed Apps and Drivers.
More likely the answer will be in your logs (past), any errors or messages there? Next, what do your runtime stats look like - anything look like a run away from a usage standpoint?
Hi, thanks for your reply, other than the System Events, I really don't know what I'm looking for, and how to access/understand some of the things you say sorry, I'm quite new to this part of Hubitat. I did think it was webcore causing the problem so moved to Rule Machine, and to be honest was a good move, but then it happened again the dreaded crash.
for the moment, remove gcal. Also look at your z-wave details page to see if you have any ghosts. If any remove. If all that is clear and it's still crashing, go to yourhubip:8081 and download your latest backup to your PC. Then do a soft reset, then restore from the one that you saved to your PC. This will ensure a clean database.
Now, if you look at your logs from the settings menu. (click past logs) Look for any lines with an error or warning and post them. We can help you from there.
From an apps perspective, I have 3 of the 4 apps that @mark21 has and my C-5 has been fine. I don't have the Broadlink app so maybe start there? Also, it's BETA so
