Things are working smoothly with Google Home and Hubitat for me lately. (After that software update that fixed that "random bulbs are offline" issue)
I'm still having the problem where asking Google to change the mode works, but google always reports an error. I searched around for people but I found threads from a few months ago.
Any tricks for me to fix this issue? I don't switch modes often but I need to sometimes and it's a little annoying.
Thanks!
Is there any possibility that Hubitat would fix this?
It should work by default, this is the error from the logs:
executeCmd- java.lang.NullPointerException: Cannot get property 'online' on null object
Thanks ansible. Your solution worked for me.
I set up virtual switches in Hubitat for each desired Mode. Then used Mode Manager to set mode with these switches. Then, Added switches to Google Home and also used in GH routines.
I usually don't use GH for mode changes but recently have been and noticed this problem is still present. Was a ticket ever created for support? Or maybe someone from HE staff can comment on if its on the list of items to be fixed.
Well, you can't use a virtual button as those won't sync to google home.
But using the built in virtual switch driver is the easiest. It has an "auto-off" function which allow it to act like a momentary switch. Once created you can sync to Google Home and then add it to a google home routine.
Thanks, I'm still using ST for mode change so I'll wait till I've moved more devices over, give them chance to fix the feedback/acknowledgement into GH
Can you get a scene to trigger a mode change? Ie get GH to trigger the scene then the scene changes the mode, or would I still need a virtual switch in the loop?
