Hubitat Exporter - Prometheus
ggiblin/hubitat-exporter: hubitat-prometheus-gateway - Bash Script and Kubernetes Pod
Hubitat Prometheus Exporter
This repo offers two solutions to get the Hubitat Metrics into Prometheus
  1. Standalone Bash Script
  2. Kubernetes Pod (in the k8s subdirectory)
A lightweight Bash-based Prometheus exporter for Hubitat Elevation smart home hub metrics. This exporter collects device states and metrics from your Hubitat hub and exposes them in Prometheus format.
Features
  • Exports device states (on/off, temperature, humidity, etc.)
  • Supports multiple device types and attributes
  • Updates metrics every 15 seconds
  • Minimal dependencies (uses common Unix tools)
  • Handles concurrent connections efficiently
  • Automatic reconnection on errors
Prerequisites
The following tools must be installed:
  • curl
  • jq
  • socat
  • base64
Configuration
Create a .env file in the same directory as the script with the following variables:
HE_URI=http://your-hubitat-ip/apps/api/26/devices HE_TOKEN=your-access-token
Replace your-hubitat-ip with your Hubitat hub's IP address and your-access-token with your Maker API access token.
Installation
  1. Clone this repository
  2. Make the script executable:
chmod +x hubitat-exporter.sh
  1. Create and configure the .env file as described above
  2. Run the exporter:
./hubitat-exporter.sh
Exported Metrics
The exporter provides the following metrics:
  • hubitat_up - Indicates if the connection to Hubitat is up (1) or down (0)
  • hubitat_device_switch - Switch state (1=on, 0=off)
  • hubitat_device_battery - Battery level percentage
  • hubitat_device_temperature - Temperature reading
  • hubitat_device_humidity - Humidity percentage
  • hubitat_device_illuminance - Light level
  • hubitat_device_power - Power consumption in watts
  • hubitat_device_energy - Energy consumption
  • hubitat_device_motion - Motion detection state (1=active, 0=inactive)
  • hubitat_device_contact - Contact sensor state (1=open, 0=closed)
All metrics include the following labels:
  • hub - Hub name
  • id - Device ID
  • label - Device label
  • room - Room name
  • type - Device type
Usage
The exporter runs on port 5000 by default. To test:
curl http://localhost:5000/metrics
Prometheus Configuration
Add the following to your prometheus.yml:
scrape_configs: - job_name: 'hubitat' static_configs: - targets: ['localhost:5000'] scrape_interval: 30s
Logging
The exporter logs its activity to stderr with timestamps. You can:
  • View logs in real-time by running the script directly:
  • Redirect logs to a file while running in the background:
./hubitat-exporter.sh 2>/var/log/hubitat-exporter.log &
  • Follow the logs in real-time using tail:
tail -f /var/log/hubitat-exporter.log
The logs include:
  • Server start/stop events
  • Metrics generation status
  • API connection issues
  • Error messages with details
Troubleshooting
  • If the exporter fails to start, check that all required tools are installed
  • Verify your Hubitat hub is accessible and the Maker API is properly configured
  • Check the logs as described in the Logging section above
  • Ensure the port 5000 is not in use by another application
License
This project is open source and available under the Elmer Fudd and MIT License.
About
Resources
Readme
Activity
Stars
0 stars
Watchers
0 watching
Forks
0 forks
Releases
No releases published
Create a new release
Packages
No packages published
Publish your first package
Contributors1
Languages
Footer
Update, added more metrics, etc
