Hi guys,
I have successfully used the Hubitat Developer Tools in VSCode to publish apps to Hubitat for almost a year now. An excellent feature that I have come to rely on. Comming back after a pause in the deveoplemt of Hubitat apps I noticed that the publishing no longer works.
Any and all thougths appreciated!
What happens when you try to transfer?
- Basically nothing. No messages, nada.
- If I do mouse over the extension I can see an error: 'Cannot read properties of undefined (reading 'scheme')'
And I can see these. I get one every time I try to publish it seems.
Did you try the Hubitat - Check Hub Connection command?
- Yes and it seems to be connected
Did you try the Hubitat - Clear all config command?
- Yes, I have no idea what config that is but I tried. Semingly nothing happened.
What has changed since it last worked?
- I had an incident where I needed to brute force shut down of the hub and reconnect it. On reconnect it was allocated a new IP address. I have updated the new IP address in HDT. I have also added the IP address in the DHCP settings in the router on a suggestion to prevent the IP address to shift again.
- I have installed some updates on Hubitat
- I installed some other ESP32, ESP-IDF related plugins in VSCode which I have used unrelated to Hubitat.
Have you tried anything else?
- I uninstalled and reinstalled the HDT in VSCode
Again, all thoughts and ideas welcome!
Cheers
