The slowdown is coming before his piston code starts executing:
CS - Child Start - Event received in child and the event delay is logged (now() - event.date)
PS - Parent Start - Child calls parent to get runtime information (commands, colors, variables)
PE - Parent Exit - Runtime information gathered, return to child
CE - Child Exit - Child variables initialized. Right before piston execution
RunTime Analysis CS < 11571ms < PS < 10853ms < PE < 221730ms < CE
Normally the exchange above is supposed to happen in ideally around 150ms, but it varies in hubitat between 300ms and 600ms if the hub isn't too loaded down. When the hub is booting up, I see delays on mine, but not to the extent of 5 minutes. If his hub is crashing, it sounds like resources are low and is reflected in the logs for the piston execution time.
I've found that if I have a piston for refreshing zwave devices (~30 devices refreshed every 3 minutes (1 every 8 seconds or so)) the hub will run out of memory and become unresponsive in around a day before needing to reset.
