Hubitat has been crashing every single evening since upgrading. There is NOTHING in the logs about what happened. It just....STOPS. I've been using Hubitat for over a year mostly without issue until these last series of updates. I desperately need to downgrade like right now. Can someone help me figure it out?
2.2.5.124
Rev C-5
I think it MIGHT have to do with duplicate logs 7X (septuplcate?) This type of logging happens throughout the day and by the evening I'm betting the logs are full.
dev:652021-01-29 08:13:30.404 pm infoDownstairs Thermostat thermostatSetpoint was set to 75°F
dev:652021-01-29 08:13:30.385 pm infoDownstairs Thermostat is pending heat
dev:652021-01-29 08:13:30.379 pm debugcmd:ThermostatOperatingStateReport(operatingState:4), desc:zw device: 05, command: 4203, payload: 04 , isMulticast: false
dev:652021-01-29 08:13:30.316 pm infoDownstairs Thermostat thermostatSetpoint was set to 75°F
dev:652021-01-29 08:13:30.295 pm infoDownstairs Thermostat is pending heat
dev:652021-01-29 08:13:30.291 pm debugcmd:ThermostatOperatingStateReport(operatingState:4), desc:zw device: 05, command: 4203, payload: 04 , isMulticast: false
dev:652021-01-29 08:13:30.092 pm infoDownstairs Thermostat thermostatSetpoint was set to 75°F
dev:652021-01-29 08:13:30.077 pm infoDownstairs Thermostat is pending heat
dev:652021-01-29 08:13:30.073 pm debugcmd:ThermostatOperatingStateReport(operatingState:4), desc:zw device: 05, command: 4203, payload: 04 , isMulticast: false
dev:652021-01-29 08:13:29.910 pm infoDownstairs Thermostat thermostatSetpoint was set to 75°F
dev:652021-01-29 08:13:29.859 pm infoDownstairs Thermostat is pending heat
dev:652021-01-29 08:13:29.854 pm debugcmd:ThermostatOperatingStateReport(operatingState:4), desc:zw device: 05, command: 4203, payload: 04 , isMulticast: false
dev:652021-01-29 08:13:29.829 pm infoDownstairs Thermostat thermostatSetpoint was set to 75°F
dev:652021-01-29 08:13:29.800 pm infoDownstairs Thermostat is pending heat
dev:652021-01-29 08:13:29.777 pm debugcmd:ThermostatOperatingStateReport(operatingState:4), desc:zw device: 05, command: 4203, payload: 04 , isMulticast: false
app:2912021-01-29 08:13:29.729 pm infohandleEvent(): Downstairs Thermostat(thermostatOperatingState:null) pending heat
dev:652021-01-29 08:13:29.667 pm infoDownstairs Thermostat thermostatSetpoint was set to 75°F
dev:652021-01-29 08:13:29.645 pm infoDownstairs Thermostat is pending heat
dev:652021-01-29 08:13:29.637 pm debugcmd:ThermostatOperatingStateReport(operatingState:4), desc:zw device: 05, command: 4203, payload: 04 , isMulticast: false
dev:4192021-01-29 08:13:29.085 pm infoKitchen Sensor: illuminance is 0lux
dev:4192021-01-29 08:13:29.031 pm infoKitchen Sensor: illuminance is 0lux
app:2912021-01-29 08:13:28.934 pm infohandleEvent(): Kitchen Sensor(temperature:°F) 69.08
dev:4192021-01-29 08:13:28.926 pm infoKitchen Sensor: humidity is 25%
dev:4192021-01-29 08:13:28.864 pm infoKitchen Sensor: temperature is 69.08°F
app:2912021-01-29 08:13:26.560 pm infohandleEvent(): Downstairs Thermostat(thermostatMode:null) off
dev:652021-01-29 08:13:26.490 pm infoDownstairs Thermostat mode is off
dev:652021-01-29 08:13:26.485 pm debugcmd:ThermostatModeReport(mode:0), desc:zw device: 05, command: 4003, payload: 00 , isMulticast: false
