Sounds like it's ip has changed. Can you confirm the ip by the DHCP table in your router? Or set a DHCP reservation then press the network reset button for 7 seconds again then try to get to it via the DHCP ip you reserved in the router.
It no longer shows an IP on the device in my eero app. Setup forwarding (which I forgot to do when I upgraded to the c8), still not working after the network reset button.
Are you attempting to connect via WiFi or Ethernet?
If WiFi, then the network reset has probably reset your WiFi credentials, and the hub does not know how to join your network.
Look at available WiFi networks on your phone, and see if there is a network called "My New Hubitat".
Or you could connect the hub by Ethernet and it will appear automatically on your network. At this time you could connect to it, enter your Wi-Fi information, and the then unplug the cable and return the hub to it's original location.
Is this true? I think last time I checked the network reset does not clear the Wifi credentials. It just sets the hub back to DHCP and clears the static IP settings. Could be wrong though.
This worked! Thank you. I remember being told not to reboot that way (pretty much at all costs) but I guess we tried everything else. Thank you so much.
To be honest I don't know for certain. I just assumed that a Network Reset" would reset all aspects of the network configuration. You are likely correct, as I am relatively new to the game.
Now having said that, based on my experiences, I think I would find a total network reset more preferable.
My suggestion of looking for the hubs internal Wi-Fi SSID, was to verify if it was unable to connect to the home Wi-Fi for any reason at all.
