Hubitat C8 hub unreachable after power outage
I am no longer able to connect to my Hubitat C8 hub following a power outage last night. Additionally, none of my scheduled automations ran this morning, indicating that there is something else wrong with my hub, beyond just the connectivity. (The automations that were scheduled to run are basic light timers built using Rule Machine, things like "turn on bedroom lights at sunrise" that have been working without issue for the two years that I have had this hub).
I have tried going to the hub's IP address (192.168.0.126), the diagnostic port 8081, and hubitat.local on different devices (a smartphone and Windows PC) and browsers, and nothing worked. The hub shows up on findmyhub.hubitat,com at the expected IP (192.168.0.126), however it doesn't load when clicking on it from here either. I have confirmed that the phone and PC are connected to the same network as the hub, and I am able to connect to other non-Hubitat devices on the same local network
The network is configured as follows:
Router (CODA-4680, provided by ISP) -> TP-Link Deco M4R -> Linksys 16-port switch -> Hubitat C8 hub
The hub is connected using the power adapter and ethernet cable that came with it, and prior to last night's power outage and this morning's issues, the hub hadn't been unplugged or moved since the initial set up and never had any issues. The light on the hub is currently green.
I have tried pressing the reset button under the hub for 7 seconds to reset it's network. The hub is now broadcasting a wifi SSID 'MyNewHubitat'. I am unable to connect to this SSID when there's an ethernet cable plugged into the hub. I tried disconnecting the ethernet cable and then I am able to connect to this SSID, however it just brings up a blank page instead of the captive portal log-in that it should.
I have also tried erasing the hub's MAC address from my router's DHCP reservation, in hopes that maybe there was a cache problem and having a different local IP might help, but... this did not help! The router's DHCP table now shows that the hub is not connected, although it still shows up on findmyhub.hubitat,com. I have also tried a different ethernet cable and port, but that didn't seem to help.
Please advise on what I can do to get my C8 hub working again!
shortly after posting this, I discovered a connectivity issue with another ethernet device on my network. Power cycling the Linksys switch solved everything!
... don't I feel silly now for not thinking of that first :sweat_smile:
Consider getting a UPS for your hub. Sudden power outages can cause database corruption.
