I have a C8 hardwired to the ethernet connection. My wifi sometimes drops and I am looking into the drops. In the meantime, does anyone know if I can set a zigbee plug to respond a wifi outage? I would like the plug to be notified by some event and then restart my router.
This would also help me pin point the time the outage start if I have the event set to once 1 minute.
If you have an always on device like a raspberry pi, NAS or PC, you may be better of keeping an eye on the Wi-Fi in that device and then reporting the status to HE.
Alternatively, if you have a Wi-Fi connected device like an Android tablet, you could set a heartbeat report back to HE in something like Tasker, then detect that the device has not checked in after X minutes.
All that said, I would warn against restarting the router based on these detectors. Instead I would suggest making some other indication that you need to look at your router.
Thanks, I did not want to manually watch the connection for the typical reason. "if my wife is home I do not want to get a call how to fix".
The raspberry idea is the right direction, but I do not have one.
The ping to the router would not work since the c8 is hardwired and always has a connection. I can ping a wifi device but I need to see if there is any on my network that never sleeps. I will check this out.
The reason I warn against automatically restarting the router is there can be too many other possible reasons for connectivity between two devices to be impacted. If you try to ping a Wi-Fi device, it could be the device that is the problem, for example. That's not to say it is a bad idea to use it as an indicator of a potential issue, just that responding automatically to a negative result may not give you the results you would want.
This was meant more as an additional check, at least IMO. If you did have a hardwired rpi checking the Wi-Fi, it wouldn't be able to tell HE if the router was down.
