Hubitat C-8 color light bulb recommendation
Sengled also has some RGBW bulbs that are Zigbee ZHA, so they won't repeat and are safe to use with your existing Zigbee mesh. Range is 2700k-6500k and RGB. They're quite stable in my house.
Hi Kilowatts - would you be able to provide a link to the exact bulb? I just want to avoid having to order/return items. Thank you!
-peter-
Just be aware sometimes Sengled are finicky to connect. I prefer the LIFX as well because they have better brightness and color vibrancy.
Cross reference the model # of a bulb on a retailer’s product page against Hubitat’s compatible devices list.
If it’s on the list, it has a built-in driver and has been confirmed by staff to work as expected with Hubitat.
Will do, thanks!
Just ordered some. You've been satisfied with it so far? Not to much pairing or connection issues?
Yes, they have been working well. I initially got 1 to try and later purchased 6 more. They are more reliable than the Sengled bulbs they replaced.
Connecting was easy. Just commission them with something like Google Home, then get the pairing code and add them to Hubitat.
Did you buy from Amazon, if so do you have a link you can share?
Cool thanks!
Yes I did. Here's the link https://www.amazon.com/dp/B0CW1NG5L3
Thank you, I just ordered them now :slight_smile:
Just received mine. I have been able to pair them with Alexa then to my Hubitat, but i d'ont have any control available for brightness and color. Also when i want to use them trough my dashboard, they're not working. It's says ''missinf attribute''. Any clues on that ?
Change the driver to Generic Matter RGBW. Click save then configure
Hi all, I just received my Linkind bulbs from Amazon.
Link to Bulb
I understand that I must "provision?" the bulb before I can add it to Hubitat. The instructions state that this requires an App AND Hub such as SmartThings App and SmartThings Hub. I have the SmartThings App on my iPhone, but do not own a SmartThings Hub. Only Hubitat Hub.
Total newbie here, can someone clarify for me? Thanks gang - this forum has been wonderful!
Below is the error I see on my phone when attempting to scan the QR code to add to SmartThings;
-peter-
You need a device that can commision Matter devices. I use a Google Hub. Here's a thread discussing what devices can do that.
This is my third purchase from Amazon to try and get a lightbulb working with Hubitat. I now understand that I need an additional, such as Google Hub to start the process.
Question: Are there any bulbs that I can use “out of the box“with habitat?
Generally any ZigBee bulb will work.
Yep did that and still not working!... I can turn it ON & OFF but can't change colors. I guess I'll have to use my Alexa app to change color and brightness when i want to
Hmm Strange. Should be able to handle that fine with that driver.
Yeah that's what i read but it seems i have no luck with that haha
