I have an old C-7 set up to use only as a dashboard using HD+ (the original). I have it connected to a small unmanaged switch and the IP of the C-7 is static at 192.168.0.50.
I have a Raspberry Pi connected to the same local, private unmanaged switch. The RPi is connected to a monitor, keyboard and mouse. It's my front end. It's IP is also static at 192.168.0.10.
If I boot all of this together, my RPi cannot see the C-7. I have tried to boot these in different order to see if that matters. Same problem.
However, if I boot everything together and then disconnect the C-7 from the private network and then connect it to my home network for about 10 seconds and then re-connect it back to the private network, the RPi can now see the C-7. I can use a browser to log into the C-7 as I had expected.
I have an average understanding of networking, but I don't understand why my RPi cannot see my C-7 after booting everything together. What happens when I connect the C-7 to my home network that makes it work in the private network? Thoughts?
So you have tested just unplugging the C7 from your private network? You have confirmed that you have to connect it to your home network and then reconnect it to your private network?
I test it by loading a browser on the RPi and try to go to the IP of the C-7, 192.168.0.50. No dice. I disconnect the C-7 from the private, unmanaged switch and connect it to my home network. Nothing else. I leave it that way for about 10 seconds and re-connect it back to the private switch. Then I try again with the browser on the RPi and go to 192.168.0.50. Now I can see my C-7 and make changes as needed.
