Hello,
For two days, Hubitat completely becomes irresponsive. I need to unplug the current and plug it back in.
The log shows when it stopped and when I unplug/replug.
It's been working flawlessly since many weeks.
Any idea?
Hello,
Any idea?
Click on the dev to see what it is... I am betting on a chromecast
unplugging can cause major corruption issues, try going to diagnostic page instead
192.168.1.92(REPLACE WITH YOUR HUB IP):8081
you'll get this page:
If the buttons don't work, try logging IN, even tho it says you're logged in already
The problem is that the IP was returning nothing. Everything was dead. Couldn't reach the Hubitat hub until I unplug and plug again.
Ah, Okay had same problem, solution, get smartthings, -no, only joking.
Create a z-wave or zigbee button through a rule to reboot hub. I have a minimote,but you can use any button device to reboot hub or even a light switch, like zooz or inovelli. Setup a triple tap to reboot hub, and it gets around the network connectivity issue that stops your accessing the hub
This has been the issue for especially when we have power interruptions. My hub becomes delayed first, then non-responsive. Usually a quick soft reset solves this. After I soft reset, then restore my backup, everything works again. The response time sucks a first, but it will get better after few days days. If there is no IP, you can plug the hub directly to a computer and type hubitat on the web browser.
What's the issue with CC's?
I used to have sporadic crashes and it was always the message shown. When I clicked on the message it was my Google home. Bptworld has a chromecast iniit program that seemed to help.
There are some discussions that talk about it.
