When I connect my iphone and hub to a private network, the Hubitat app will not load, only displaying the initial flash screen.
What do you mean by private network?
I have them connected to an unmanaged switch and both have static ip addresses. ie, not connected to any other network or the internet.
What do you mean by connecting your iPhone to your switch?
If my Wi-Fi connection does not have Internet access, the phone will automatically use the cell data for any data requests. So I wouldn't be surprised that you couldn't access the hub locally.
However your problem is that the app refuses to open at all.
If I turn off both my Wi-Fi and cellular data, the Hubitat app still loads. It displays
MyHubName (Cloud) (Offline Mode). You may also want to try turning off both Wi-Fi and cell data to see if the symptoms change, and the app actually opens.
I am using an Android device, but I think this proves that the app should open regardless of what type of network you have.
If you are unable to test for proper operation on a regular network (i.e. with a router and Internet access) then I suggest clearing the cache of the app. If that fails then uninstall and reinstall the app.
Still curious about how the iPhone is connecting to Hubitat via a switch that is itself not connected to the rest of the LAN.
An Ethernet dongle?
yes, lightning to ethernet dongle
I grabbed an old TDS modem, turned off the wifi, and now use it instead of the unmanaged switch so that I can have DHCP, which SEEMS to work better, especially if I do have to connect to my home network for updates and the like.
