Hubigraph and LTS with mysterious data truncating
Hi folks - been using Hubigraph built in app for some time now. I have also setup LTS for key attributes and it seems to be storing the attributes when i look at the files in file manager. HOWEVER, when i go to create/view graphs, i get bizarre data truncating for some attributes and not others (i.e. on a week long plot i get feel week data on one LTS attribute and only 24 hours on another).
I also can't seem to explicitly select LTS as the data source for the attribute. Hoping someone can shed light on how to set this up right with LTS. I'm tempted to scrap the setup and start from scratch. Thank you!
You might want to consider moving you graphs over to webcore. The developer took the Hubigraphs code and incorporated into webcore. He made some significant changes in how LTS is handled. I had a few graphs that would randomly erase my LTS data when using hubigraphs, that has not happened since I switched to using the webcore version.
You can import you LTS data from huboigraphs into webcore and it will translate it to the webcore format. It is a bit cleaner as it uses EPOCH time instead of a the plain date format. A bit harder to read, granted but much cleaner and the files are smaller.
The other advantage is that webcore is supported Hubigraphs is not.
Thank you for the tip to take a look at Webcore. I'm at end of rope with Hubigraph and have started to look at Webcore graphs. I just built first graph but it is getting stuck drawing the chart at 4/4 even after 5 minutes and a super simple 1 attribute graph over 1 hour. I must have a setting messed up somewhere
The setup is basically the same as Hubigraphs, so yeah you probably missed something. I was able to move all my graphs over with no issues.
