HubAction UDP Parse Warning no longer working
The parseWarning: true function no longer works in returning a timeout. Impact is if there is an error (i.e., incorrect IP), there will be no response from the hub. You only get confirmation if the communications was successful.
(I have a work-around; so no immediate impact. But the work-around involves a a runIn and setting a state (once on sending and once when a normal response is received).)
