I am trying to use the HubAction Object shown below to control a device and receive a return. It utilizes Encoding.HexString and I was expecting a HexString as a response.
Mind if I ask how you converted to hex specifically? Also, I think that some of the responses to actions are base64 encoded as well... or at least the response is if it's an error or something like that. I don't remember for sure and of course I didn't leave myself notes in the drivers where I do this kind of thing.
What is the response.type? If it's error-looking you might have to:
response.payload.decodeBase64()
To see the exception message is. I've never done it with Protocol.RAW_LAN though. I've just done that with Protocol.LAN for type HubAction.Type.LAN_TYPE_UDPCLIENT, and all the HTTP ones.
I’m not at a pc so grabbing this on my phone. I’ll look closer tomorrow. I use raw lan in my Kohler dtv+ driver. I have to get the payload like this to decode a json response.
Just for fun don't base64 decode the message unless you know it's an error. And if it is an error... And if that doesn't fix it also just for fun instead of using parseJsonFromBase64... try:
parseLanMessage(response).payload.decodeBase64()
I only base64 decode error messages when using the UDP action. Maybe the RAW_LAN action is the same way and only base64 encodes error messages. So, maybe no decoding required.
I was experimenting out of desparation. Converted the string (resp) to a byte array then used hexutils to convert the byte array to hex. It did not return the correct hex string.
Well, hold on. Why are you going ASCII? You didn't say you needed to get into ASCII.
Do you know it's ASCII coming back? Maybe it's not 1 byte characters but 2... UTF-8 or something.
I do this to convert out of hex because my characters are 2 bytes each (take 2 at a time). Here's the hold method for convenience:
private String unhexify(String hexStr) {
StringBuilder output = new StringBuilder("");
for (int i = 0; i < hexStr.length(); i += 2) {
String str = hexStr.substring(i, i + 2);
output.append((char) Integer.parseInt(str, 16));
return output.toString();
Thanks to all for the help. The below works. Your responses led me to this solution. The response is not an error message, just not converted back to Hex as it is in the UDP messages when Hex encoded.
def parse(response) {
// Parse the response, extract the payload, and convert to Byte Array
Byte[] respArray = parseLanMessage(response).payload.decodeBase64()
// Send response to the XOR decrypter and create a JSON Output
// Note that String(respArray) is the Hex string response from the device.
def cmdResponse = parseJson(inputXOR(new String(respArray)))
// Result is the expected response from the device.
log.debug "Return message is ${cmdResponse}"
The result is the decoded response in JSON format.
