HUB6 integration
I know the hubitat has its own security options. However, I like a wired security system. I have an old DSC system I have plugged a HUB6 into, and the setup was SUPER easy. Basically the HUB6 integrates like a keypad into the system. Good enough for my needs. It even notes my zone names.
Does anyone out there also use HUB6?
Has anyone found a way to integrate with HE and HUB6? I chose the HUB6 over the Konnected.io option after significant consideration. Mainly, I connected 4 wires to the HUB6, and I was done. If the konnected.io option simply interfaced like a keypad, I would have gone that route. But, it doesn’t. I wanted to keep my system intact (without having to connect each and every zone parallel) as I have multiple keypads and about 18 zones.
There does not appear to be a direct integration. Have you reached out to Hub6 to see if their device has a status page, can provide a JSON response to an HTTP(s) query, or some method like that? If they do, a custom driver could probably be written to at least give you status information (and depending on whether they have an API, possible control). I did not see anything on their website though that immediately stood out for those possibilities.
I did find using it with IFTTT though. SAFE By HUB6 works better with IFTTT
So again, there has to be a system behind it that could be read at the very least.
