C4. Ver 2.2.4.158
All but 2 or 3 devices are zigbee. Some have been slower to respond lately and yesterday the zigbee network failed, so I rebooted. Everything I've checked seems to be working, but I thought I'd shut down and pull power for 20 minutes. From settings menu, I selected & OK'd Hub Shutdown. It just stalls with the message "Hub shutting down". Everything continues to work. No red leds.
I rebooted -which did work- and tried again. Same thing happens, stalls on "Hub shutting down."
What's the procedure for manually forcing a shut down?
That's weird.
Have you tried directly querying though http://hubitat.local/hub/shutdown
or http://hubitat.local:8081/ ?
I had tried http://hubitat.local/hub/shutdown and that returns Error 404
I had not tried http://hubitat.local:8081/ and that did bring up a different options menu from which Shutdown did work. Thanks!
That's because it requires a "post" not a standard "get"..
Glad it worked for you. but I would still email support and let them know shutdown from the main UX isn't working for you. That sounds like a pretty bad bug.
