I have a C7 Hub running version 2.4.4.155 and today ever since my public IP changed, I am not able to connect to the Cloud (alert says cloud connection unavailable).
I have worked on fixing this for the last several hours. I have tried the following:
- Ping cloud.hubitat.com and my gateway from the Network Test, which both reply.
- Update time
- Released the Fixed IP reservation and rebooted the hub and the Gateway (Unifi UCG Ultra)
- Disabling and reenabling the Cloud from settings
- Rebooting the Hub
- Shutting down the Hub and unplugging for a couple minutes
- Restoring from a backup, from before the public IP change.
- Soft Reset
- Reboot with Database Rebuild
- Pushing the small button on the bottom of the Hub for 7 seconds to reset the network interface.
- Deregistering the hub from the cloud - I somehow registered it back to the cloud after I did a soft reset, but then it still says the cloud is unavailable
I also have a second hub, on a different subnet (attached to this network) that I am setting up and that one works fine and is able to connect to the cloud. I am really running out of ideas of how to get this hub up and running again.
Anyone have some thoughts on this?
