Hub Variables Broken?
Going to Settings, Hub Variables doesn't seem to work. There is no Add Variable, and Delete isn't active. Is there another place to manage these now?
According to the documentation (and from what I remember) you could do everything by going to Settings -> Hub Variables
Hit Done, you had clicked on DryerLastBatteryLevel in the leftmost column, which shows which apps are using that variable.
OK, that works. I hadn't clicked anything, so not sure why it thought I did - this was literally the first time visiting this page in months
