Hub Variable changes require Dashboard refresh
I'm having an issue displaying the current value of Hub Variables in Dashboards. When the Hub Variables are changed within RM actions, the Dashboard will not reflect the updates until it is manually refreshed. This is using v2.3.1.128 on a C-5 Hub.
I've recreated this behavior using an integer Hub Variable and a few Virtual Buttons to increment or decrement the value in a Dashboard. When you press a button, the Hub Variable tile does not change. However, if I use two tiles that reference the same Hub Variable and use the tile to change the value, both will update in real time.
I appreciate any feedback on how I can accomplish this.
Viz.
Hub Variable:
Simple dashboard:
Log activity for Hub Variable changes and Button presses:
Dashboard only updates after a manual refresh:
Changing the Hub Variable from the Dashboard results in a real-time update:
Immediately after "Save":
We will get this fixed.
Many thanks. That was an incredibly quick response.
