Currently running version: 2.2.2.127
New Version Available: 2.2.2.126
WARNING: This is a downgrade to your current version.
Whats that all about????
It appears they may have pulled the 2.2.2.127 release? Tagging @bcopeland as he may know more.
If you don’t use the maker api it shouldn’t effect you.
Correct .. 2.2.2.127 was pulled, there was a major issue with it in regards to makerapi which is what the hotfix was for.. I do recommend going back to 2.2.2.126 if you use or plan to use makerapi. Otherwise it makes no difference, as this was the only change.
I was just about to report a major spate of makerapi errors overnight. Thanks for the update!
Thanks for the knowledge
