Hub Update Hung
I just tried to update my C7 Hub. Progressed normally but hung while extracting. http://10.0.0.4/ is now inaccessible. Suggestions?
Can you access hubIP:8081 http://10.0.0.4:8081/
Also may want to check to see if the hub may have changed IP addresses.
Thanks for the response. The hub ip It did change from 10.0.0.4 to 10.0.0.5. I recovered from hung update process via portal.hubitat.com and restoring from backup.
Lesson learned: do not deleted downloaded update file until update completes.
Should also be:
Assign a static IP address to all things HA.
Set a reservation in your DHCP for the HE or set a static IP directly on the HE so you don't get bit again :slight_smile:
