Hubitat Elevation Software update 1.0.7.710 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click ‘Update Hub’. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.0.6.709
- Increased Zigbee transmission power
- Re-enabled garage door option for original ST multisensor
- Updates to Generic Zigbee thermostat driver
- Updates to color transition for Zigbee color bulbs
- Fixed Rachio exceptions
- Mode Manager bug fix for time settings not firing
- New feature for Mode Manager to set mode upon return from Away based on the time settings
- New feature for Simple Lighting to allow toggle as an action
Dashboard - Fixed garage door misc state changes
- Reset 5 minute refresh after each layout update
- Fixed date in clock-date template
