Hubitat Elevation Software Update 1.0.3.704 is now available.
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and from one to two minutes to perform the update after you click Update.
We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.0.2.702
Bug Fixes:
Footer Links all open to new tab
Zigbee Startup changes
Z-Wave Command fixes
Manually added Drivers now run installed method on creation
Fixed Portal Registration Issues that users have reported
Zigbee Generic Bulb fix
Hubitat Safety Monitor smoke detector fix
Lutron Integration fixes
Fixed timezone clock setting problem
Fixed Rule Machine bug in build 703
Additions / Changes:
App Generated Token for OAUTH2 endpoints can be sent as Bearer Token in Headers
Option to discover Z-Wave devices already joined to USB Stick
Fixed display of HTML/XML on the logging page
Optional delay parameter for Zigbee Commands
UK SMS support
Dome Leak Driver
Generic Z-Wave Water Sensor Driver
Iris Button Driver
Rule Machine:
- added Fade Dimmer to Level over Time
- changed Custom Commands to child apps
- added Poll() action
Added Garage Door functionality to SmartThings v1 multi sensor
