Time syncing to wrong date (and possibly time)
I am on version 2.1.3.127 with a C5
Recap. Several days ago there was a problem with the hub losing connectivity from the hubitat cloud. Since then a hot fix was put in place but ever since I have been having problems with the date sync being off by three days. What is odd is the date is changing right around the same time as the cloud issue from days before, 10:20PM ET. Coincidence?
I determined that the time change right around 10:20PM using the System Events log. The last last entry was 10:18PM ET until I synced the time using Settings/Hub Details.
Added: I confirmed that it is not an issue with the NTP as all my devices use a central NTP on my network and no other devices are having this issue.
