Updated my hub to the latest version yesterday(2.0.8.112), since then the time is one hour behind.
I did do the update time from browser and the time was fine then restarted the hub since then the time is off again.
This is now causing problems with the sunrise and sunset routines that I have.
Is anyone else having issues since the daylight savings change over the weekend?
Based in the UK.
I am having issues with mode changes. They are happening an hour later than they should. E.g night mode should start at 23:00, changes at 00:00.
My sunset routine is working at the correct time.
I have my location set as Europe/London.
Thanks iangw2018 for checking my nodes are doing the exact same thing.
Also the api seems to be a hour behind ?
When itโs actually
My time is OK. Itโs just the mode I have an issue with. I notice you are showing the time as GMT, whereas I am showing BST.
Good spot iangw2018, mine was set to Etc\Greenwich for some reason ( pretty sure this was set to ETc\london before... )
I have changed mine now will keep a eye on it! and have a look into the modes now
