Hi everyone,
First post, and I'll apologize in advance for making it a long one!
I'm a recent Wink convert, purchased and initially set up my Hubitat in May 2020.
Here's my setup:
Hubitat Elevation® Platform Version 2.2.2.129, Hardware Version Rev C-5
~15 ZWave swtiches/Dimmers
1 Schlage lock
Castea Pro Bridge (w/ 3 dimmers + 3 Picos)
Apps I use (all native):
Amazon Echo Skill
Hubitat Dashboard
Lutron Integrator
Rule Machine 4.0 (7 rules)
Starting nearly two weeks ago, I noticed that my automation rules weren't activating every day (turning lights on in the evening). Then Alexa voice commands would time out. Then I noticed that I couldn't pull up the hub web page or dashboard. A hard reset (pull the power cable) got it working again. A day or two later, same thing happens. After about a week I noticed that it seems like I need to reset daily to keep it working. Not good.
So, the other day while I had it in this state, I fired up Wireshark to try to sniff out what's going on. (I'm a software engineer, can't help it.) I can share the pcap file if anyone wants to see it. What it shows is that my browser is able to establish a TCP connection on port 80, so it's somewhat functional through at least the session/transport layers. TCP keep-alives are even successful, keeping the connection active. But the Hub won't respond to an HTTP GET request, leaving the browser spinning and spinning. It's clearly hung at the application layer.
After resetting, I was able to pull the logs, and see a trend that the errors (SQL exceptions, Groovy-lang exceptions) that seem to start 20-24 hours after each reset.
For example, here's the most recent lockup which occurred on 8/8. Today I reset the hub on 8/12 to recover it and grab these logs. During the lockup period, no entries were recorded for any physical switch activations. (newest logs first!)
dev:192020-08-12 07:54:37.009 pm infoTelnet connection to Lutron interface established
<Edit: ........LOCKUP PERIOD......>
dev:192020-08-08 07:30:56.381 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (heartbeat)
dev:192020-08-08 07:30:56.370 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:192020-08-08 07:23:40.264 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
dev:192020-08-08 07:23:33.068 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
app:222020-08-08 07:23:14.956 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] on line 154 (LutronHandler)
dev:192020-08-08 07:22:59.161 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
dev:22020-08-08 07:22:45.829 pm errorgroovy.lang.MissingMethodException: No signature of method: static org.codehaus.groovy.runtime.DefaultGroovyMethods.asType() is applicable for argument types: (java.lang.String, java.lang.Class) values: [00 00, class java.lang.Object] Possible solutions: asType(java.lang.Class), any(), grep() (parse)
dev:22020-08-08 07:22:45.819 pm errorgroovy.lang.MissingMethodException: No signature of method: static org.codehaus.groovy.runtime.DefaultGroovyMethods.asType() is applicable for argument types: (java.lang.String, java.lang.Class) values: [00 00, class java.lang.Object] Possible solutions: asType(java.lang.Class), any(), grep() (parse)
dev:192020-08-08 07:05:36.899 pm inforcvd: OUTPUT,6,1,100.00
app:42020-08-08 03:51:07.354 pm errorError making Call to refresh Token: Remote host closed connection during handshake
dev:102020-08-08 02:00:56.311 pm infoCloset is off [physical]
dev:102020-08-08 02:00:36.921 pm infoCloset is off [physical]
dev:102020-08-08 01:51:50.462 pm infoCloset was turned off [physical]
dev:102020-08-08 01:46:55.588 pm infoCloset was turned on [physical]
dev:212020-08-08 01:19:42.184 pm infoMasterBedroom was turned off
dev:192020-08-08 01:19:38.312 pm inforcvd: OUTPUT,6,1,0.00
dev:152020-08-08 01:07:47.080 pm infoEvening was turned off
dev:92020-08-08 12:01:20.083 pm infoPatio is off [physical]
Previous powerup timestamp was about 21 hours prior:
dev:192020-08-07 10:13:14.730 pm infoTelnet connection to Lutron interface established
Previous lockup was with this error:
dev:22020-08-07 05:33:38.584 pm errorgroovy.lang.MissingMethodException: No signature of method: static org.codehaus.groovy.runtime.DefaultGroovyMethods.asType() is applicable for argument types: (java.lang.String, java.lang.Class) values: [00 00, class java.lang.Object] Possible solutions: asType(java.lang.String, java.lang.Class), asType([Ljava.lang.Object;, java.lang.Class), asType(groovy.lang.Closure, java.lang.Class), asType(groovy.lang.GString, java.lang.Class), asType(java.io.File, java.lang.Class), asType(java.lang.CharSequence, java.lang.Class) (parse)
app:42020-08-07 04:07:42.159 pm errorError making Call to refresh Token: Remote host closed connection during handshake
Older crashes on 8/6
dev:192020-08-06 04:12:03.267 pm errorgroovy.lang.MissingMethodException: No signature of method: groovy.sql.Sql.executeUpdate() is applicable for argument types: (java.lang.String, java.util.ArrayList) values: [UPDATE DEVICE D SET D.STATE = ? WHERE D.ID = ?, [{"lastHeartbeat":1596744469849,"reTryCount":0}, ...]] (heartbeat)
dev:192020-08-06 04:12:03.248 pm errorgroovy.lang.MissingMethodException: No signature of method: groovy.sql.Sql.executeUpdate() is applicable for argument types: (java.lang.String, java.util.ArrayList) values: [UPDATE DEVICE D SET D.STATE = ? WHERE D.ID = ?, [{"lastHeartbeat":1596744469849,"reTryCount":0}, ...]] (heartbeat)
dev:22020-08-06 04:12:03.243 pm errorgroovy.lang.MissingMethodException: No signature of method: groovy.sql.Sql.executeUpdate() is applicable for argument types: (java.lang.String, java.util.ArrayList) values: [UPDATE DEVICE D SET D.STATE = ? WHERE D.ID = ?, [{"polled":0,"bin":1,"flashing":false}, ...]] (parse)
dev:192020-08-06 04:12:03.230 pm errorgroovy.lang.MissingMethodException: No signature of method: groovy.sql.Sql.firstRow() is applicable for argument types: (java.lang.String, java.util.ArrayList) values: [SELECT D.STATE FROM DEVICE D WHERE D.ID = ?, [19]] (heartbeat)
dev:22020-08-06 04:12:03.230 pm errorgroovy.lang.MissingMethodException: No signature of method: groovy.sql.Sql.firstRow() is applicable for argument types: (java.lang.String, java.util.ArrayList) values: [SELECT D.STATE FROM DEVICE D WHERE D.ID = ?, [2]] (parse)
Before that on 8/4
dev:22020-08-04 03:36:46.696 pm errorgroovy.lang.MissingMethodException: No signature of method: static org.codehaus.groovy.runtime.DefaultGroovyMethods.asType() is applicable for argument types: (java.lang.String, java.lang.Class) values: [00 00, class java.lang.Object] Possible solutions: asType(java.lang.String, java.lang.Class), asType([Ljava.lang.Object;, java.lang.Class), asType(groovy.lang.Closure, java.lang.Class), asType(groovy.lang.GString, java.lang.Class), asType(java.io.File, java.lang.Class), asType(java.lang.CharSequence, java.lang.Class) (parse)
dev:22020-08-04 03:36:46.697 pm errorgroovy.lang.MissingMethodException: No signature of method: static org.codehaus.groovy.runtime.DefaultGroovyMethods.asType() is applicable for argument types: (java.lang.String, java.lang.Class) values: [00 00, class java.lang.Object] Possible solutions: asType(java.lang.String, java.lang.Class), asType([Ljava.lang.Object;, java.lang.Class), asType(groovy.lang.Closure, java.lang.Class), asType(groovy.lang.GString, java.lang.Class), asType(java.io.File, java.lang.Class), asType(java.lang.CharSequence, java.lang.Class) (parse)
If I go back and search old logs for "error", here are the oldest errors on the device....
dev:22020-08-02 11:20:44.979 pm errorjava.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:22020-08-02 11:17:15.870 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22020-08-02 11:17:12.420 pm errorjava.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:22020-08-02 11:15:35.509 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22020-08-02 11:15:32.062 pm errorjava.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:22020-08-02 11:13:43.790 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22020-08-02 11:11:58.662 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22020-08-02 11:10:12.865 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22020-08-02 11:04:57.831 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:192020-08-02 11:04:54.868 pm errorjava.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. (parse)
dev:22020-08-02 11:03:25.283 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22020-08-02 11:03:25.234 pm errorjava.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:192020-08-02 11:01:41.971 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
dev:192020-08-02 11:01:41.977 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
dev:22020-08-02 11:01:41.971 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (parse)
dev:192020-08-02 11:01:41.941 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
dev:192020-08-02 11:01:41.942 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
dev:22020-08-02 11:01:41.944 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (parse)
dev:192020-08-02 11:01:41.943 pm errororg.h2.jdbc.JdbcSQLException: The database has been closed [90098-197] (heartbeat)
app:42020-08-01 01:16:05.966 pm errorError making Call to refresh Token: Remote host closed connection during handshake
app:42020-07-31 02:24:22.670 pm errorError making Call to refresh Token: Remote host closed connection during handshake
The vast majority of errors seem to be on dev:2. Dev:19 shows up a few times, and dev:21 and dev:22 even less. I also see app:4, which is the Alexa interface, but that failure may just be a symptom of the crash.
Dev:2 appears to be a Leviton Z-Wave dimmer "Kitchen", although the profile lists it as a generic Z-Wave dimmer. I just updated it to be a Leviton, and turned on debug logs. Dimmed it, turned it off, turned it back on using a virtual device (that controls multiple lights via the rule manager). Working fine, nothing interesting in the debug logs.
Ok, so where do I go from here? I expect I'll be back tomorrow evening with more data to share. But I'm really hoping this doesn't turn into a "factory reset", where I need to exclude and reconnect all of my devices to clean out the database. I'm embarassed to admit that I don't have a database backup before this issue began, as I haven't fully integrated all of the devices the way I want them. And by the time I realized I had a serious issue, I was well past the 5 days of automatic backups... Ugh.
Should I remove and re-include the offending device(s)?
