I shutdown one of my hubs (in the mesh) so I could plug it into the UPS. After I restarted it, it was super slow. In fact, some times any given webpage timed out.
Remembering I had a similar problem a few weeks ago which I "solved" by restarting the other hub (in the Hub Mesh), I shutdown the 2nd hub. Voila, the first hub was back up to speed and behaving normally. I then restarted the 2nd hub which is now running super slow. I have rebooted it several times but it hasnt improved anything. The 1st hub was still running normally and I am afraid to restart it only to have both hubs going to a crawl.
I have considered disabling the mesh but I am concerned about the automation I have setup. Will these be restored when I re-enable the mesh? Anyway, I am looking for a solution that will allow me to shutdown any of my hubs without having it come back up and running at a crawl.
Looking for input
UPDATE: I can confirm that once I rebooted the 1st hub, which is running normally, the 2nd hub speeds up and runs normally. Unfortunately, the 1st hub now is slow.
I suspect the code in question is beyond my view. There is no custom code. I can duplicate this issue at will and the logs show nothing. I can turn off (any) one hub and the other works fine. If I turn off both and restart them at the same time, the problem disappears within minutes of startup. If I restart one, wait, restart the other, I am back at square one. The only commonality ithat I can see is "Hub Mesh".
Let's try turning off hub mesh refresh on the affected hub.
Look under Settings - Hub mesh - Full remote device sync interval (at the bottom of the page). Set it to Never.
Actually, this happens to both hubs. The one which will run slow is the one last up and running after shutdown. Should I turn off hub mesh refresh on both or just one for now?
I can see that on one hub, the app|56|Remote Control is throwing a significant number of errors and on the other, you have a problem with dev|115|Home Assistant Device Bridge
Both are running well atm but I still like to get to the bottom of this. As I said above, I can make the problem come back by shutting down and restarting it. Would you like me to shutdown Cors Hubitat 2 and try it?
I am watching it now but I see no errors. The ones you noted in the past log were a log.info statement which I disabled. The error was due to this statement, at times, referencing a null device. The last error was over an hour ago. At least what I can see at my end. You see errors more recent??
My one hub (#1) has once again slowed down after a shutdown. This morning I did some electrical work in my basement which required me to shut down several servers and the 2nd hub. Once I was done with wiring, I restarted everything along Hub # 2 . This hub is running fine. Hub #1 on the other hand which was not shutdown with the rest of the equipment, is back to its slow downs as I described above after I powered up all my equipment in the basement.
The only changes I have made since my last post above was disabling descriptionText logging for most, but not all, devices. I also had to exclude and reinclude a zwave switch this AM which was no longer responding to any command.
While some would like to blame custom apps/drivers, these hubs run fine until one of the hubs is shutdown and restarted. Once I "fix" this slowdown it never re-appears till the next shutdown. Prior to any of these slowdown both hubs were running 9 days without issue.
