Have a remote system with 2 hubs. Hubs are connected via Hub Mesh. I can remote admin into the main hub. Everything in the 2nd hub is controllable from the main hub, in other words Hub Mesh is up and working meaning 2nd hub is online and ok.
In my.hubitat.com, registered hubs, it shows remote admin active but it's grayed out. And thus I can't connect to it.
I’m guessing it didn’t phone home for some reason. But not sure how to make it do so. Being an hour and half away makes it hard for me to locally connect. About the only thing I can have the guy there do is unplug. But if that’s what it takes I can probably recover if something gets corrupted.
That narrows it down to something more specific to the hub that can’t reach the internet.
Could be an IP address/DHCP issue, or DNS, maybe something in the router like a firewall rule or some other kind of block on WAN-bound traffic from the hub.
I’m sure that’s not an exhaustive list, but you have to rule out one possibility at a time if you want to know where exactly the problem is.
