Hub Monitor, empty zigbee logs, and notifications
Still having problems with notifications not notifying. This caused a serious issue with temperatures in vivaria today. Hub sends to Hubitat app, hubitat app doesn't talk to notifications on the phone despite the options being set..
But more concerning is zigbee log after a few days doesn't do anything just a blank page, if I reboot it comes back, but after a while same thing again. All the devices are connected and logs are normal. Someone else had this as a symptom of a dying Hub.. Any suggestions?
Trying to install Hub Monitor and I can't select the hub, I just get a half of the drop box however I try to access it. Using chrome on Android in both phone and desktop modes and I really need to monitor what this thing is doing.. Is there a way to solve this?
It's broken and doesn't look like it will ever be fixed. I looked at but could not figure out how it detected the hub info devices.
My understanding was Hub monitor was incorporated into Hub Info, is that correct @thebearmay ?
@RosieUK Use Pushover for notifications, it never fails. You can also change notification sounds based on severity
Hub Monitor (v1.0.12 15 Jan 2023) no longer picks up the original Hub Info driver but should pick up the v3 Hub Info driver. Easy way to override if you don't want to change info drivers is to change line 73 to
 input "qryDevice", "capability.*", title: "Hubs to Monitor:", multiple: true, required: true, submitOnChange: true
