Looking at moving from C5 to C7 and while trying to plan it all out a question came to mind. Is there any advantage to creating "Hu Mesh" prior to moving devices? Just trying to cover all the bases before starting and figured I'd ask.
I have both C5 and C7 interfaced with HU Mesh! As you might have been reading, there is some interoperability of the C7 and select Z-Wave devices that are better suited to the C5's 500 radio than on the C7.
As much as I would like to have the C7 contain all the devices, apps, etc, it looks like this isn't possible with some legacy devices and S0 security on new devices.
I have started what I think will be a slow transition from a C-4 to a C-7. The reason I expect it to be slow is I have several devices that are difficult to access and I would like to wait before transitioning them. So I expect to be running both hubs for some time - likely several months.
What I have done so far (and I make no claim that this is the "right" way to do it):
I got my C-7 working. This C-7 was new but had been sitting on a shelf since late summer while I waited to see the resolution of the Z-Wave issues. Getting it working required a weekend working with Bobby to get the platform updated, the diagnostic tool updated, and the Z-Wave firmware updated.
I let the C-7 run a couple of days and then I updated the C-4 to the latest version as well.
I took backups of both (even though there was really nothing on the C-7).
I tried out moving one Zigbee device, a motion sensor in my office, to the C-7 and then linking the two hubs with Hub Mesh to see how that all works.
I decided that for the long run, I will want most of the automation routines to run on the C-7. Not wanting to have to re-enter them all, I decided to take a shot at restoring my backup from the C-4 to the C-7. What the heck, I only had one device on the C-7, how bad could it be?
Since I was not ready to transition the automation routines yet, when the C-7 came back up after loading the backup, I went into location and corrected the name back to what I had assigned it (something with a 7 in it) since the backup had put the name from the C-4 on it (because it was in the backup). Then I went into the apps page and disabled all the apps by clicking the little box.
I also disabled the Z-Wave radio. I'm not ready to move Z-Wave devices yet. I am focusing on moving most of the Zigbee devices because I have had the Zigbee network go offline a couple of times and Bobby suspects it may be a hardware problem - thus my motivation to begin using the C-7.
So I have all the apps on both hubs and they are all disabled on the C-7. I have all the device entries on both hubs but no Z-Wave devices are joined to the C-7 and the Z-Wave network if off for the time being.
I've moved 5 zigbee devices over this afternoon and I have found what seems to be a pretty good procedure. Let me know if I have made it too complicated (I've been known to do that).
- I choose a device to migrate to the C-7 hub.
- On the C-4 hub I rename the device, appending -OLD to the end of the name.
- On the C-7 hub I initiate the Zigbee Pairing and click or push buttons on the end device to join.
- When the device is recognized it will automatically fill-in the name as the device is known and in the database.
- At this point I go into the hub mesh menu on the C-7 and share the local device.
- Then I go to the hub mesh menu on the C-4 and link to the device that I just shared on the C-7. This creates a device entry in the device list on the C-4 for the device on the C-7.
- Next I look at the original device entry on the C-4 to see what apps were using the device and I go into each of those apps and select the "new" device which will have "on {the name of my C-7 hub}" appended to the name, if necessary (depending on how the app works) I also remove the "old" device with the "-OLD" appended to the name.
- Once I have switched the devices in all the apps that the device was on, I can delete the "OLD" device.
It's actually not as cumbersome as it might seem in writing. I can do it pretty quickly and by saving the old device until I am ready to remove it, I reduce the risk of losing some key piece of configuration information.
As I do more, I will try to remember to come back to this thread and provide updates.
Yeah, I've documented as much as I can and just wanted to see if having the mesh would help or hinder. I will most likely move Zigbee first as well. Have about 26 of each so it's a toss-up. Mostly concerned about keeping all my rules intact. Thanks for the input.
I think (hope) that by doing the backup on the old (C-4) early on and loading that on the new (C-7) hub, I won't screw up the copies of the rules on the new (C-7) hub with the name changes (appending -OLD) to the devices on the old hub (C-4). When it comes time to transition the app operations to the new (C-7) the names that are already in the (C-7) should be correct when I turn off the sharing on those devices.
I haven't experimented with that yet. I think that will be my next (baby) step will be to transition a very simple rule from the C-4 to the C-7 and see how that works.
Yeah, probably my biggest concern, having to make all new rules.
This has worked well, so far. I have moved all but two of my Zigbee devices (around 35) from the C-4 to the C-7. Most of the automations are still running on the C-4 with the C-7 connected devices linked to the C-4. A few of the automations were quite simple and compact so I enabled those on the C-7 (and disabled them on the C-4). Those turn on lights or fans so I shared those lights or fans from the C-4 to the C-7.
I am quite impressed with how well the Hub Mesh works and how easy it is to configure it. It looks to me like a good bit of thought went into the steps needed to configure the hubs and the screen movements are tailored to what you will likely need . . . very cool.
No conflicts with rules on both? Did you import a backup from your C5 to C7 then fix the devices and rules as you moved them.
I backed up the C-4 and restored that backup to the C-7. I corrected the Location Name on the Location tab, I disabled all the apps on the C-7 by clicking the little box to the left of the app name (the optional box that you have to turn on by clicking the X at the upper right), I also disabled the Z-Wave radio since I wanted to work on migrating the Zigbee devices first.
Based on what Bruce had mentioned, the devices don't do anything until you pair something up - the entries just sit there,
To move the Zigbee devices:
First I renamed the device on the C-4 hub by appending "-OLD" to the name (it turns out I didn't need to do this but it did make it easier to find these in the list of devices),
Next I reset the device (the Join and Reset Instructions were a huge help - Join and Reset Instructions - Hubitat Documentation),
then I started the Zigbee Pairing on the C-7,
then I executed the device join procedure (on most of them this is just the reset procedure so it's all one step).
The devices are recognized because of loading the backup so I didn't need to do any device configuration.
For most of the devices, after joining them to the C-7, I shared them in Hub Mesh, then went to the Hub Mesh page on the C-4 and Linked to remote device. That creates a new device entry that has "on {name of the C-7 hub}" appended to it (this is why it's not critical to rename the old device - I renamed them anyway).
Still working on the C-4 hub:
I go to the device entry for the old device (since I renamed it, I can just search for OLD),
go to the bottom of the page to the "In Use By" section and click on each of the Apps where the device was used,
edit the app to de-select the "-OLD" device entry and select the "On {name of the C-7 hub}" device entry.
Save the App.
Fix anything else (so far this has only been dashboards - after changing the device entry in the Dashboard App, you have to edit the dashboard itself to change the device referenced by the tile).
Once you do this with all the Apps where the device was used, there will be no more Apps listed under "In Use By", at that point I deleted the "-OLD" device entry.
Then test the App to make sure it is working correctly.
I am in the process of adding a new C7 to replace my C5. I have been reading this thread with interest. I am actually now thinking of adding the C7 separately for now and moving my z-wave devices (only about 7) to take advantage of the new chip. Then if I read this correctly I can turn on Hub Mesh and mirror those devices to my C5 and use them as if they are attached directly to that Hub?
That is correct
Just be aware that Z-Wave pairing to a C-7 can be painful. Itโs much better than it was at introduction, but there can still be some bumps in the road. Once paired, and after โghost nodes โ from the pairing process have been removed, itโs fine.
A little more information on my setup. I have a large z-wave network running on Homeseer. Have been slowly migrating to Hubitat for some time.
I am focused on my Kwikset 910 door locks right now - working horribly under Homeseer.
So I decided to move two of those over with some repeaters to see how they performed on the C5. A little better, plus I installed the reliable lock app that at least lets me know when the locks haven't responded.
I was thinking of moving these over to the C7 to see how things go. It can't be any worse than what I am dealing with now or on Homeseer. If better, great, if not - nothing lost.
So perhaps a fools errand!
