I cannot speak to RM stuff but to see if it would work with NR before installing you could install a Maker API instance and then do a direct call via your browser:
http://[your Hub IP address]/apps/api/[Maker API ID]/devices/[Your Switch ID]/on?access_token=[Your Access Token]
http://[your Hub IP address]/apps/api/[Maker API ID]/devices/[Your Switch ID]/off?access_token=[Your Access Token]
It would appear that its me that works intermittently, not HE! (well probably 50/50 in this case) id messed up the motion rule and so the reason the lights were not coming on, is because id told them not to!
Welcome @markvk42 to the facepalm club
- you are in excellent company!!
{group hug}
Just been looking at node red.... rabbit hole here i come.... if only i can fid a pie to buy!
I wish this was more obvious. I spent a few days trying to troubleshoot this stuff, because my mesh randomly stopped working. Took a couple weeks to rebuild it all and test various methods to actually get the devices to even show up.
