Hub Mesh Question
Question:
I have a Aeotec Dual Nano Switch which I just installed.
No Problem.
It made up two component switches.
There is a Hub Mesh enable/disable switch on the parent, but not on the two component switches.
How do I mesh the component switches individually?
For the devices I have when I set the parent device to be shared on hub mesh the child device is shared as well.
What happens if I don't want the parent, just the children?
Doesn't look like that is an option. Did you try deleting the parent device after sharing? I would imagine it would delete the child device as well but I have never tried it.
If you delete parent it will also delete the children. Unfortunately hubmesh requires parent and children and no way to select just a child device.
