Hub Mesh from a C7(actual devices) to a C4(meshed devices) is no longer showing. All the + signs to add devices to my C4-from my C7 show "null". Tried rebooting both hubs, same issue. Lots of + signs on the C4, but all are null.
Is it the upgrade? Anyone else seeing this issue?
Just checked on my C7 with C5 and C7 linked device and all of them are okay.
That other hub is probably running 2.3.2. It's a known issue, not sure about exact resolution timeline.
2.3.3.122 on both hubs, I made sure before I posted.
Should I try a soft reset?
No, that will not make a difference. I'll need to take a look at the engineering logs on the hubs, could you please PM me the hub ids?
Well here we go, and without explanation it started working, at some point. And it wasn't after the reboot, even after doing a F5 refresh.
If you want the UUID's anyway., let me know
I am getting the same issue in 2.3.3.137. From linked devices it is not showing all the hubs that are listed in active hubs. Existing devices seem ok but I able unable to link a new switch. I have done a reset, restore which didnt fix the issue.
Any ideas?
Appears to be a capacity issue. Deleted an unused linked device and made room for the one I wanted to use.
