Hub mesh not connect with 2.3.4.139
Does anyone have hub mesh working with 2.3.4.139?
Yes, it's working fine for me. But there was a change made in .138 which got rid of UDP connections, so make sure you're using TCP, especially if you jumped past .138 to get to .139.
That’s what I was trying to find where to change it at.
There was also a port change, so both (or more) hubs need to be on the same firmware version, or at least .138 or newer.
Both of them are running the same firmware version. I’m just not finding where to change the ports at.
That was done with the update. No user intervention. Have you tried shutting them down and restarting?
Or look at settings/hub mesh/reconnect
Rebooted and reconnected both at least twice. I’m wondering if eero is blocking it……
Some of the Eeros default to a /22 instead of a /24 subnet... which really is irritating. Is yours one of those?
I changed all my hubs to TCP before updating and everything came back almost immediately
