Hub Mesh Linked Devices page issues
There seems to be some issue with Sorting on the Hub Mesh "Linked Devices" page .. probably other as well.
I have multiple devices on multiple hubs.. one issue is that after clicking on the "+" sign to add, the hubs randomly flip around top/bottom/middle
So when I go to Linked Devices tab..
I see
"Linked devices on this hub"
xxxx device xxxx2 device
yyyy device
Available on Hub -ABCD
  • device a1 + device a2 +device a3 +device a4
    +device a5
Available on Hub - EFGH
  • device b1 + device b2 +device b3 +device b4
    +device b5 +device b6
Available on Hub -IJKL
  • device c1 +device c2 +device c3 +device c4
Available on Hub - MNOP
  • device d1 +device d2 +device d3 +device d4
Lets say I clicked on the plus sign for device a2 and then "Yes" on the prompt to add.
once the page refreshes, then
it randomly reshuffles the hubs..and now I might see
NOW I might see all the hubs randomly sorted..
yyyy device +device a2
+device d1 +device d2 +device d3 +device d4
  • device a1 +device a3 +device a4
    +device a5
The second is.. more of an annoyance than an issue..
I have about 80-90 devices on 2 hubs.. and there is NO WAY to multi-select and add those devices.. clicking "+" and then "Yes" on the confirmation on 200 device gets really boring !..
I would request Hubitat folks to make it possible to add multiple select /add available on this "Linked devices" screen. and fix the random sorting issue as well.
I thought rather than create a separate topic I might slip mine into this one as it's not a major deal and could hopefully be fixed at the same time.
I noticed the device URL for devices on other linked hubs that have not been linked currently has "undefined" as the hub name / IP in the address, so does not resolve. Not causing me any issue, just something I noticed.
I see this too.
The latest update completely broke my mesh. I tried all sorts of BS to get it working. UDP vs TCP, etc. Ultimately I had to disable mesh completely on both, regenerate the tokens, and unshare the devices. Then deleted the ghost devices on the other side.
After reconnecting everything, I'm seeing the devices come across as undefined.
I reached out to Hubitat Support about this on August 5th with zero response, so I would not get your hopes up to have this fixed. Better off to figure it out yourself. Maybe just use Home Assistant to connect your multiple hubs instead.
